586,270 active members*
3,538 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Posting from esprit cam to a hurco VMC
    Sep 2014
    Hi, I work for a small machine shop that just purchased esprit cam. I need some help getting NC code into our Hurco's.
    We have been able to post programs out to our Mazak turning center. But we have had no luck with posting to our Hurco's (vm20i, vm10).
    Is there a tutorial somewhere, or some advise?
    Esprit has given us the latest post processors for our machines. We have tried running the code that Esprit generates with no luck, the hurco just says unknown g code.
    Does running NC code use the same tool library that the winmax conversational programs use? Is there anything else that needs to be set up for this to work properly?
    Jun 2008
    1104
    Re: Posting from esprit cam to a hurco VMC
    Make sure you are using Industry Standard NC on the Hurco instead of Basic NC. Or vice-versa if your post is set up for basic.
    Sep 2014
    I am fairly certain the post is set up for industry standard. I know the hurco is.
    I will double check that.
    I will try and get a picture of the code, and the errors that I am getting.
  1. Replies: 2
    Last Post: 08-06-2013, 03:09 PM
  2. posting code in esprit
    By bohoballer in forum Esprit
    Last Post: 12-04-2012, 02:49 PM
  3. problem posting MCX5 posting to Cimco edit v5.6
    By cdmmachining in forum Mastercam
    Last Post: 05-10-2012, 02:09 PM
  4. I miss Esprit and Esprit Mold
    By DIFF OVER in forum Esprit
    Last Post: 05-10-2012, 03:18 AM
  5. posting to a hurco kmb1?
    By mmachining in forum BobCad-Cam
    Last Post: 12-19-2007, 02:48 AM
