586,779 active members*
9,401 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas PCOOL Programmable Coolant
    Sep 2014
    My company purchased an 07 VF2 that seems to have a flaky PCOOL unit. Despite low hours, there seems to be a long history of alarms with the PCOOL. I saw the following prior posts:
    http://www.cnczone.com/forums/haas-m...t-failure.html
    http://www.cnczone.com/forums/haas-m...nt-nozzle.html
    http://www.cnczone.com/forums/haas-m...cool-help.html
    The unit seems to have (and can be) driven past the limit. I downloaded the electrical service manual but that only serves to confuse me further because it shows cable 200 as only four conductors. A cable 180 is mentioned but not detailed in the manual. The PCOOL unit that is installed has at least seven conductors:
    2 wires to the motor
    2 wires to upper microswitch (senses motor rotation)
    3 wires to lower microswitch (senses end of travel limit)
    There also appears to be a surface mount resistor in clear shrink sleeve. I though I read in one of the posts that the resistor kicks in when the lower switch reaches end of travel to limit current. The Grainger motor mentioned in the one post does not look like the motor in my unit.
    When the unit was first opened, it was driven past one end of travel. It was physically put back, but the motor seems weak to drive yet it is not binding. I suspect the lower switch (NC/NO) may be wired backwards, even the the labels match the switch. The switch itself operates properly on both sides.
    Can anyone provide a better idea of how this thing is wired (color code)?
    -Thanks-
    Re: Haas PCOOL Programmable Coolant
    Couple of questions:
    1: Can you post some pictures of the unit and associated connectors.
    2: How many positions does your PCOOL have. Old style 20 position or the newer 30+ position model?
    I have done some repairs on the older model 20 polsition model. i.e. replacing the microswitch that counts the steps.
    John
    2007 HAAS TM-1P OneCNC XR5 Mill Pro. Shopbot PRT running Mach3 2010 Screen Set, Super PID and PMDX Electronics.Check out my Gallery on: http://[email protected]
    Jul 2004
    100
    My service tech was here on Tuesday. He told me that sometimes the work will bump the tube or someone will try to move it by hand. The internal gears are plastic and sometimes get damaged.
    Regards, Ray
    ​"There is no such thing as a gun free zone."
    Ray Brandes, Ray-Vin.Com, PCB, FL 32408 USA
    Oct 2014
    John i am having some issues with my pcool on a vf2.. i took it apart to check it out and now i forgot how the dang wires go... here are some pics any help would be awsome..
  1. Haas PCOOL nozzle repair/replacement.
    By dresnerm in forum Haas Mills
    Last Post: 08-05-2014, 11:17 PM
  2. HAAS PROGRAMMABLE COOLANT PARTS
    By gregoryblaine in forum Haas Mills
    Last Post: 11-07-2013, 08:50 PM
  3. PCOOL (Programmable Coolant Nozzle)
    By HelicopterJohn in forum Haas Mills
    Last Post: 11-10-2009, 05:59 PM
  4. Programmable Air/Coolant for HAAS Machines
    Last Post: 04-02-2009, 03:29 AM
  5. Haas programmable coolant unit problem
    By xs-speed in forum Haas Mills
    Last Post: 01-30-2008, 06:54 PM
