586,499 active members*
3,061 visitors online*
    Sep 2014
    Red face Step Four precise 760 Mach3 setup
    Hello i have an Step Four precise 760 cnc Router running xpertmill.
    The company no longer exists so i need a new Software.
    What do i need to run this machine with mach3 ?
    i tryed everything ports and pins, is it the controller ?
    i have the Xpertlink STEP-FOUR - Schneiden und Fr controller connected via USB and Ethernet.
    is this controller useless with mach3 ? it costet me over 1k bucks.
    i want to use 4 axis milling with one rotary.
    thank you in advance
    Re: Step Four precise 760 Mach3 setup
    Unless it has a Mach3 plugin, it will not work with Mach3.
    Sep 2014
    Ok thank you, so what do i need to buy to get it working for 3d milling?
  1. newbie question on step by step cutting setup/ process in Mach3
    By Matt Clara in forum Mach Software (ArtSoft software)
    Last Post: 05-27-2014, 07:36 AM
  2. Kflop Dir / Step setup time
    By BobKinsman in forum Dynomotion/Kflop/Kanalog
    Last Post: 11-16-2012, 12:10 AM
  3. Replies: 0
    Last Post: 06-11-2010, 03:27 AM
  4. Mach3 Step By Step
    By brouser1 in forum Mach Plasma / Laser
    Last Post: 04-09-2010, 03:46 PM
  5. A Axis and Step and Direction Spindle Setup
    By mklb in forum Mach Software (ArtSoft software)
    Last Post: 11-27-2009, 02:19 PM
