586,917 active members*
2,557 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > producing a rad with ballnose cutter with heidenhain controller
Results 1 to 2 of 2
    Apr 2008
    32
    Is it possible to produce a rad along a length of material with a ballnose cutter? I would like to be able to do it WITHOUT the use of cam software .
    So.... for instance ..... if I have a piece of material 100mm long and 50mm wide and 50mm high, and it has a 16mm rad along the 100mm length, how could I program it.....simply.... or not...using a 10mm ballnose cutter and heidenhain controller ?
    Thanks in advance .
    Jan 2005
    1121
    Re: producing a rad with ballnose cutter with heidenhain controller
    yup
    define an yz circle center, move in small incremental polar movements then run the x the length of the part
  1. Heidenhain 2500 controller
    By wanda 1 in forum Bridgeport / Hardinge Mills
    Last Post: 07-04-2014, 12:11 AM
  2. Bridgeport heidenhain controller?????
    By bherr in forum Bridgeport / Hardinge Mills
    Last Post: 10-30-2012, 06:41 AM
  3. heidenhain 426 controller/DMU 80
    By km8137 in forum Controller & Computer Solutions
    Last Post: 11-04-2011, 03:59 PM
  4. Heidenhain 151BQ controller
    By bob S in forum Controller & Computer Solutions
    Last Post: 01-20-2009, 02:28 AM
  5. HEIDENHAIN CONTROLLER
    By alexanderstrand in forum Uncategorised MetalWorking Machines
    Last Post: 03-15-2008, 11:28 AM
