587,030 active members*
3,517 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mastercam x5 Help!!
Results 1 to 7 of 7
    Sep 2014
    5
    Mastercam x5 Help!!
    Hello, I am trying to scale and image in xyz on mastercam, i can get it to look right on mastercam, but when i save it as a dxf and view it it is all jacked up, Pleas help!
    Sep 2014
    7
    Re: Mastercam x5 Help!!
    Is everything on the top view, on the X,Y plane?
    Sep 2014
    5
    Yes, We have a cnc plasma at work, its pretty old stuff, it has sigmanest on it, so i recently got mastercam and have been creating parts on it and saving them as dxf files and then importing them into sigmanest, its been working great, but i used rast2vec, to upload a picture, and i scaled it out in xyz to size and saved it to dxf so i could load it on the plasma, and when i view it as dxf it is all over the place, the lines and arcs are all off, Any help is really appreciated
    Sep 2014
    5
    It may be something simple, i know if i scale in uniform it comes out fine, but i cant get it to the size i need, as soon as i scale in the x direction it throws everything off when i view,
    Sep 2005
    13
    it could be as easy as saving it as a an older veirson dfx like a 2002 or an r13
    Dec 2008
    3122
    Quote Originally Posted by Shide View Post
    +1
    also if you scale axes independently ( not uniform ), a circle becomes an ellipse, which in Mastercam is output as a spline ( polyline ) which may be what is giving the problems
    - convert all splines to lines & arcs, you will have to play around with your procedures & settings to get it right, as many,many lines gives large files & slows your machine down as it executes them
    Sep 2014
    5
    I really appreciate the replies guys, Superman, What you said is exactly right, thats what it is doing, i just didnt know how to convert the splines and the procedure to get it right, Im pretty new to mastercam, teaching myself.
  1. MASTERCAM OR NOT TO MASTERCAM. THAT IS THE QUESTION.
    By Jonathan E. in forum Mastercam
    Last Post: 03-06-2016, 08:33 PM
  2. Replies: 4
    Last Post: 07-03-2014, 05:45 PM
  3. Converting Mastercam Files without Mastercam.
    By OutlawMachine in forum Uncategorised CAD Discussion
    Last Post: 04-16-2014, 11:38 PM
  4. Replies: 1
    Last Post: 03-17-2014, 08:49 AM
  5. nesting mastercam x or mastercam x3
    By zewanil in forum Mastercam
    Last Post: 05-21-2009, 07:30 PM
