586,127 active members*
3,311 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Polishing on a Lathe - Ballpark Parameters
    Aug 2010
    57
    Hi all.
    I have a small job to do and thought I'd try my hand at finishing it out with polishing to get a nice, smoother finish. I have my lathe set up, and all of my shafts are cut to +.0005 to +.001 within the finish diameter.
    I have nice long thin strips of 60 grit emery cloth here.
    Now, what rpm should I be setting the machine at and how long should it take to remove .001" off of 1045 steel? (my max rpm, btw, is 3,500 - but I'm nowhere near comfortable leaning over the machine at that speed with an unbalanced lathe dog).
    I originally had the machine spinning at 600 rpm and it took FOREVER to do one shaft. It's a good thing I have nothing else lined up to do.
    Following some advice here and on some other, lesser, forums, I upped the rpm to 2000 but it still seems to be taking a while - probably 1-2 minutes to knock off .0001".
    Am I doing something wrong or am I just expecting too much? I have 19 shafts left to do and boy, do I not want to spend a lot of time just polishing (if I have to, I will. Just a preference).
    Mar 2006
    2712
    Re: Polishing on a Lathe - Ballpark Parameters
    What's the surface finish before you start polishing? 1045 can be hard. Has your piece(s) been hardened? You might look into a Cogsdill single point burnishing tool, could be used on other finishing jobs as well.
    Dick Z
    DZASTR
    Aug 2010
    57
    it was pre-hardened CR. I got it finished, took a long dang time. It was a smooth surface finish. That burnish tool looks neat though.
  1. Am I in the ballpark? 1/2" aluminum
    By 4EyedTurd in forum Uncategorised MetalWorking Machines
    Last Post: 10-24-2013, 04:55 PM
  2. Hand Polishing with CNC Lathe in Spindle Jog?
    By alexlaughlin in forum Safety Zone
    Last Post: 10-16-2013, 03:59 AM
  3. Ballpark Costs Momus CNC
    By utamaverick2004 in forum Momus Design CNC plans
    Last Post: 10-22-2012, 06:57 PM
  4. Ballpark tool life
    By jack_box_spring in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 06-10-2010, 04:07 PM
  5. Hardinge HLV - Ballpark
    By bjinatj in forum Hardinge Lathes
    Last Post: 09-23-2009, 03:43 PM
