586,463 active members*
3,486 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Fanuc 10M Spindle Drive Trouble
    Aug 2008
    28
    I have an older Leadwell VMC with a Fanuc 10M Control. I had been running the same part for quite a while and the machine was running fine. I programmed another job and noticed that the spindle would only run 2 speeds (1) when programmed at or below 1100 rpm and(2) when programmed 1100 or over. So, until I had time to look into the problem, I kept running at the higher speed.
    Not long after, the spindle alarmed out (#2 LED on spindle drive) and was running ROUGH. motor was loud and skipping.
    Today I removed the Honda connectors to the spindle drive, cleaned the pins, connectors etc., started the machine, and it was running a lot smoother, but only 2 speeds still.
    When I run the spindle manually with the rheostat control, I noticed that the spindle load was about 30% until the knob passed the midway point. Then the spindle load maxed out and ran rough.
    I spoke to a few local techs and have been told that it was a sensor in the spindle motor and was an easy fix. I have also been told that it is a spindle drive problem with a hefty price tag.
    I dumped the parameters a while ago and am not sure if the speeds ever changed correctly when I reentered the parameters
    I want to be sure that what is done is needed and not a waste.
    So, I am wondering if this has happened to anyone and what to do to fix it,or to at least try to isolate the problem
    Spindle motor: A06B 1006 B100
    Drive A20B 0009 0530
    Any help would be greatly appreciated.
    Mike
    May 2012
    32
    Re: Fanuc 10M Spindle Drive Trouble
    I know this is an old thread , but i had this problem. It was the Square sine wave feed back setting out of sync. It was fixed with an Ohm meter and manually spinning the spindle by hand while power was off so set it back properly.
    Aug 2008
    28
    Can anyone explain exactly how to reset the sensor?
    Thanks!
    May 2012
    32
    Mike,
    I helped my CNC repair guy. You need 2 people. One to spin the spindle and the other to read the meter and adjust the "clock face" wheel on the spindle drive board. Im sure if you explain to a tech guy exactly what you want him to do, instead of him troubleshooting it wont cost much. It took us 10 mins. (plus milage, plus lunch, ))
  1. FR-SE spindle drive trouble
    By cut more in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-21-2018, 07:06 PM
  2. Fanuc spindle drive trouble
    By Drew in forum Fanuc
    Last Post: 05-30-2013, 01:59 PM
  3. Fanuc spindle drive trouble
    By Drew in forum Uncategorised MetalWorking Machines
    Last Post: 05-26-2010, 03:24 PM
  4. Fanuc spindle drive trouble
    By Drew in forum Servo Motors / Drives
    Last Post: 05-24-2010, 06:56 PM
  5. fanuc 15 m spindle trouble
    By nabil_elbadri in forum Fanuc
    Last Post: 01-11-2008, 01:36 AM
