Originally Posted by
cowanrg
cool, this is good information and pretty much what I expected. I will first try to shim the motor mount forward/backward to see if I can get the belt riding in the right spot. Then I need to address the bore on the motor pulley. It's definitely not concentric. I should have done them on a lathe, but I don't have a lathe, yet.
CRO-WD40, can you explain what you mean:
"You can shim the motor equaly so you can fit the straight edge inside to measure whats not parallel.
Then remove those shims and add them where they are needed."
