586,493 active members*
1,505 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Part file to dxf or dwg
    Oct 2013
    153
    Hi all I am having a problem while saving the part file or assembly file to dxf or dwg the converted file size is huge it's around 70MB . But if I use my colleagues system to convert those files it comes out good in few KB's . What should be the reason for the bulky out out ?
    Jun 2008
    562
    Re: Part file to dxf or dwg
    Are you saving the "Part model " or the drawing file as a DXF? My DXF files of drawings are about 1/20 of the "drawing" file size
    Mike
    Oct 2013
    153
    Drawing file as a DXF . By the way if I use a default drawing template it's ok . But the customized template gives me a bulky file . But the same temple works well in a different system . I am using solidworks 2014
    Jun 2008
    562
    Mike
  1. Part File
    By 1QWK96GT in forum GibbsCAM
    Last Post: 07-14-2011, 08:05 PM
  2. Part to STL file save
    By SPEEDRE in forum Solidworks
    Last Post: 05-11-2011, 02:33 PM
  3. Converting a pdf file to UG part file
    By gaoxingdcf in forum UG NX
    Last Post: 05-20-2010, 01:47 AM
  4. Replies: 3
    Last Post: 12-11-2008, 02:45 PM
  5. All sides one Part file
    By wmFlipper in forum GibbsCAM
    Last Post: 02-04-2007, 09:34 PM
