586,283 active members*
3,594 visitors online*
    189
    uncommanded A axis movement when doing 4 axis work.
    Benn playing around with meshcam trying yo do some 4 axis carving.
    Everything works fine until I pause the program in mach.
    When I hit the "Cycle Start" button to resume machining The A axis (rotary) takes off to somewhere instead of holding it's position as it should.
    I'm using the Mach 3" post in meshcam..
    Any ideas anybody? Thanks!
    Is a sentance fragment?
    Re: uncommanded A axis movement when doing 4 axis work.
    Do you have the A axis configured as Tangential? Just a guess.
    Aug 2014
    889
    How long of a pause? I noticed when using feedhold if you walk away from the machine for extended period, Mach3 just drops the port access or something like that and can't resume. Maybe that is part of the problem?
    189
    I'ts usually the next morning after pausing it for the night. I used to pause stuff all the time on three axis jobs overnight all the time with no probs. I wonder why it's just the A axis? If had a post that added the A command to every line I wonder it that would fix it?
    Any idea one how to write a post like that?
    Thanks!
    I
    Quote Originally Posted by G59 View Post
    189
    Thanks!
    I
    189
    don't think so ...
  1. TB6560. Y and Z axis work fine but not the X axis
    By crimar in forum Stepper Motors / Drives
    Last Post: 04-16-2014, 01:45 AM
  2. X axis differential to create Y axis movement.
    By mpatterson557 in forum Uncategorised CAM Discussion
    Last Post: 03-10-2014, 12:18 AM
  3. uncommanded z movement when using MDI
    By rstbkt in forum Mach Mill
    Last Post: 11-29-2013, 04:00 PM
  4. Grinding and unexpected axis movement if rapiding 2 axis
    By DarkSabre in forum Taig Mills / Lathes
    Last Post: 03-26-2010, 05:37 AM
  5. Axis Movement
    By KARD in forum CamSoft Products
    Last Post: 05-21-2008, 11:29 AM
