586,745 active members*
6,701 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Help with servo tuning - Maxsine EP1 - typical error
    Oct 2003
    128
    Just finished updating my Bridgeport Series 2 from steppers to servos.
    Using Mach3, Hicon board and Maxsine EP1 drives which accept step & direction. The machine basically runs great. 200 IPM rapids on X & Y, 120 on Z
    The Hicon plug in has a utility that shows the following error on the drives and is used to test the acell + speed change the maximum allowed error but does not actually tune the drive.
    Servos are completely new to me so I do not know what to expect but the following errors seem pretty large. X & Y are about 8400 counts which = .084. Is this too much? I have attached a spreadsheet with my settings & calcs.
    Does anyone have any experience they would like to share tuning these? There is a mini-USB port on the drives, I was hoping there is some software to do this. I have googled till I'm blue and cannot find any.
    Attached Files Attached Files
    Marc
    Feb 2007
    966
    Re: Help with servo tuning - Maxsine EP1 - typical error
    Yes 8400 counts is huge.
    Have you read the manual and got the tuning software from where you bough the drives ?
    Jun 2013
    1041
    Wow. I would think that a following error of 20 counts at max speed would be a lot closer to reasonable.
    Ben
    Oct 2003
    128
    I finally got the software last week. This is my first time tuning servos so I am learning as I go. My first attempt dropped the error by a factor of 10-20. Now I am down to 800 or so on X & Y, 300 or so on Z. But I agree that still seems like a lot.
    What is a typical acceleration setting for a Bridgeport type machine?
    Marc
  1. VF-2 servo tuning
    By Rstewart in forum Haas Mills
    Last Post: 12-20-2018, 02:22 PM
  2. Replies: 3
    Last Post: 08-08-2016, 08:55 AM
  3. EZ Trak Calibration, Tuning & Error Compensation
    By TRASHVOID in forum Bridgeport / Hardinge Mills
    Last Post: 08-27-2010, 06:43 PM
  4. Servo Tuning HELP!!
    By Julian M in forum Servo Motors / Drives
    Last Post: 07-18-2010, 01:06 AM
  5. Servo Tuning
    By gbowne1 in forum Fanuc
    Last Post: 11-07-2009, 05:31 AM
