For the Pulsar, I am making a real enclosure rather than the shower curtain. While the shower curtain worked okay, It would not work as well with a wash down system that the Pulsar has.
Cleaning out the tanks and chips on the Torus was a nasty job and took some time every week.
The upgraded stand should make it a rather easy task. Initial impression just from seeing it is that it is a far better design.
I will be using aluminum extrusions and fiberglass panels. Polycarbonate on the front sliding doors. Should be rather simple. I have everything I need on hand already. I had bought it to do a full enclosure on the 80/20, but never got that far. It is still using it's old half enclosure. If it doesn't leak, it's still working.
I'll post more later.
