586,409 active members*
2,860 visitors online*
IndustryArena Forum > CNC Electronics > Dmm Technology > minimum pc requirements
Results 1 to 5 of 5
    Apr 2012
    141
    so ive got a couple kits from dmm, the dyn2 and the dyn3 systems
    what sort of pc requirements are needed ..... ive got an old mini ITX 1.2ghz machine running XP that would be quite awesome if i could use it purely due to its size .....
    i think with some time and careful planning the whole system could be fitted into a std size pc case ...
    but what is the minimum spec for a dmm kit ?
    ta
    Feb 2007
    711
    Re: minimum pc requirements
    The computer doesnt really have anything to do with it, unless you want to run the dmmdrv software, I guess anything that runs windows XP or newer will work.
    Apr 2012
    141
    Ash yes makes sense I think ;-)
    It's more a question of what requirement does mach3 need
    Jan 2005
    15362
    Quote Originally Posted by Bl@ckrat View Post
    A pentium 4 ( 3.0 to 3.4 G ) with 2G of ram works very well with Mach3
    If you run your Dmm with a Smooth Stepper, ( which you should ) the computer for Mach only needs to be the minimum as above
    Mactec54
    Oct 2013
    1
    Im looking for drawings on the DMM dyn2 3 axis servo kit connected to the Ethernet smooth stepper im not an expert with wiring but have an idea on reading drawings need help wiring the system! Any help appreciated
    cncstagz
  1. Looking for 2'x3' minimum CNC
    By Tim Schoenhals in forum Want To Buy...Need help!
    Last Post: 08-07-2014, 09:14 PM
  2. Minimum system requirements
    By thedoctor in forum SheetCam
    Last Post: 10-17-2008, 09:16 AM
  3. Minimum laptop requirements
    By cncuser1 in forum Mastercam
    Last Post: 09-11-2008, 12:25 AM
  4. Minimum System requirements?
    By bcnc in forum Mach Mill
    Last Post: 03-02-2008, 11:53 PM
  5. Minimum PC system requirements please?
    By Oldmanandhistoy in forum Mach Software (ArtSoft software)
    Last Post: 07-17-2006, 02:47 AM
