Controlling Rigid Tap Depth
Hi All,
I am working out the bugs in a "new to me" Haas VF-2 that I just got about a month ago. 1997 VF-2.
I was making some parts today and drilling and tapping some blind holes in aluminum. Setting up the first part, on a job I do all the time, I noticed that the blind holes at .5" deep in a .550" thick piece of aluminum were bulging on the bottom of the part. I reset all the tools thinking must have screwed up, but it did the same thing. I then checked the depth of the drilled holes and found them to be good, but when it tapped the first hole again it bulged out the bottom. So I took the part out and watched the position screen as it went through the tapping cycle for four holes.
What I found was that the tap that was supposed to go .47" deep was actually going about .54" deep and pushing the material out the bottom. Thank goodness for a strong 8-32 form tap. I change the depth for the tapped holes to .35" and kept running the parts.
I don't have the original manual for the 1997 but I have it for my 1996. After going through the parameters I found a setting, number 120 (SPINDLE ACC/DECEL), and found that my 96 was set at the factory setting of 25. I checked the 97 and it was set at 20. Since I figured it was time, I changed the 1997 to 15 and ran the tapping cycle again. It was only off about .03" of the proper depth setting. I dropped #120 to 10 and now it is within about .003 to .005". Hard to read it exactly. So I changed my program back to the .47" depth setting and it is fine now.
That setting, #120, does not seem to change anything else that I can see, so does anyone know if it will cause an issue someplace else?
Thanks for you time. Thought someone else may need the information.
Cheers----Mike
