So I have a 48 volt power supply running a 5056D driver that is running a 906oz stepper now. I can use the 5056D driver on my lathe conversion and purchase a KL-8070D 80VDC/7A Digital Stepper Driver (It will take an input of 72 volts) for the mill's z axis (906oz stepper already mounted). The problem is all my other stepper drivers run on 45 volts and I only need one 72 volt leg to drive the KL-8070D and 906oz stepper combo. Is this a need or a want....the million dollar question.
What I don't know is if my 5056D and 906oz stepper performs better than if I would have just bought a 570oz stepper to be run by the 5056D.
I haven't bought the electronics for my lathe conversion yet so I can still change things a little. I am contemplating using:
-two 570oz steppers and two 5056D's (one new and one from the mill if I convert to KL-8070D)
-C10 BOB (purchase a C11 and an Ethernet Smooth Stepper to replace the current C10 for the mill)
-48v/12.5a power supply
Open to suggestions......
If you bought the KL34H295-43-8A or 8B 906 oz/in stepper from Automation Tech it's best to run it at a max of 58 volts, 72 volts would just overheat it.
The benefit of using the 8070d would be in getting the amperage for the 906 for full torque.
The 906 with the 5056d and a 48 volt supply is proven to work well for the g0704 even though it "detunes" to about 742 oz/in, still more than enough.
570's are plenty for the g0602.
Hoss
Vertcnc - can you show pictures of your limit switches installed - particularly y and z axis? Looking for the best place to mount a switch that look exactly like what you have.
Thank, Mike
Give me a day or so and I will post some mounted pictures. The y switch is mounted on the base in the rear near the center of the column. I extended the plunger on the switch about 14" long and have shaft collars that are tripped by a bracket mounted on the saddle. The Z is mounted on the saddle of the head and moved up / down with the head with the stops mounted on side of column.
You posted up some pictures on some of your older posts. As far as I could tell you used the same mounting methods Bob Warfield shared in cnccookbook.
Thanks for the pics!
