Originally Posted by
cwhiley
The process for machining these involves a lot of detail filing with a hand file before they are machined. Well, naturally since the cycle is nearly 6 minutes long, you spend time between cycles doing that as well as pre-drilling the side mounting holes, and tapping these same holes after they are machined. Well, I managed to machine 142 units on this evening's shift. If you do the math, that's 71 cycles. Now, there is a bit of lost time between cycles to remove the finished parts, air hose the chips off the fixture, and mount the next pair of parts into the fixture. You have to pay attention as a crooked part or slight misalignment will cause a bad part or worse yet broken tools. So if you work 8 hours that's 480 minutes. So if there was ZERO time to cycle the parts in and out you could theoretically do 80 cycles per 8-hour shift. Since there is about 15-20 seconds between to swap parts this adds up over time and you lose out a bit.
So I broke my personal record tonight and did 142. Pretty damn good in my opinion. PLUS I left 84 on the table ready to rock. Which leads to my point....the truly aggravating part...
All week I have left a surplus of hand filed and drilled parts ready to be machined. When I come in and relieve first shift, I have less than half of what I left the previous night on the table to machine. So the guy that works the other shift, in my humble opinion, is just taking all of my hard work, and making his job easier. He's able to take it way easy because there are so many ready to run. I figured he would be good about it and still file as many as he normally does, but he's using my extra hard work, and leaving me with scraps when I relieve him. This has happened 4 days in a row. The worst was Monday when I left him with 80+ on the table ready to go, and when I came in there was only 35. He's been there 3+ years. I've been there 4 weeks. So I feel like there's ZERO incentive for me to work this hard. Granted the machine can only do so many per hour, so having a "buffer" that large is not necessary. But what it does allow you to do is spend more time inspecting, and testing screw holes, alignment, and quality of the finished part. (I'm very concerned with quality control right now because I'm new and want to catch any mistakes as early as possible to prevent mistakes, and manual re-works/repairs) But everyday I've come in all my "buffer" is practically gone so I'm forced to bust ass again, just to make sure I keep the machine running. I always eventually catch up, but I'm tired of being taken advantage of...if you understand where I'm coming from. I've decided I'm going to stash my buffer under a work bench or something....because it's not fair that his productivity is just as good if not better than mine, simply because he's able to take advantage of what I'm leaving. To add insult to injury this Mexican guy is just unfriendly as all get out, and there seems to be a real attitude he has against me.
The thing is they've NEVER had a 2nd shift till I got hired....so he's never had anyone working the same parts as him until now. I dunno if he feels threatened, doesn't want to look bad, or is just a jerk, or is racist, but there's definitely animosity. It's not just a language/cultural barrier, that much is certain.
I know this much....I ain't going to work this hard just so he can take his time feeding the machine, and me struggle, whilst it looking like he's actually more productive when he's not. Pretty much, the environment at this point promotes mediocracy and doesn't encourage high levels of productivity. There ought to be a bit of cohesiveness and teamwork but apparently not...so I'm going to solve it myself and just put my extra work aside where it's not noticed, and when he leaves I'll pull it all out and then I can take a little more time on quality control, and basically not bust my damn ass nonstop....because it's clear there's no reward for doing that. Also, I'd like to spend a bit of time watching the cycle in detail, and paying attention to the code being run so I can see a working example of the G-code instructions and how the programming actually works. I don't know if I mentioned it earlier but I have 15 years of I.T. experience, and know a great deal about computers and worked as a programmer for a university years back. Esentially I got in legal trouble a while back, so I'm having major troubles getting through most H.R. departments to stay in my industry...so I'm at this plant. I spend some of my free time watching milling basics youtube videos, am trying to pour over the Haas programming manual, and am also trying to get my feet wet with MasterCAM and SolidWorks....but I have no idea what I'm doing so I am just trying to locate videos, and training materials online as best I can. At this point I'm just getting the applications installed. HAven't even run them yet. I have a bit of AutoCAD experience as well from a couple classes I took as a graduate student but nothing too serious. See, I'm childhood friends and schoolmates with the owner and he's expressed to me that he wants me to learn how to program....but I'm not given any clear direction as to how or when I'll ever be able to do this. It's all just run run run production. I think after my 90-day probation period is up I am going to suggest I come in an hour or two earlier....before I relieve 1st shift and spend that time playing around with MasterCAM, SolidWorks, and G-Code.....otherwise I'll never get a chance to learn how to do this stuff.
Anyhow, appreciate you guys reading all this and listening to my rant.
