Re: Do any of the mills actually work?
Something the size of the Sieg X2 or G0704 might fit your bill. Those are up to the sort of parts you describe. As for the best compromise of mill quality and capability, the Taig is the best bet on your list. Just a little lighter duty than the bigger machines, but in my opinion superior to the Sherline and has very nice build quality.
All of these machines can be converted and will work. The stuff about scraping etc, can make a machine better, but often is done when people are looking for higher accuracy than the standard machine will deliver. If you want to make relatively small parts in aluminium mostly, to a tolerance of around ±0.2mm then a well-executed conversion should deliver that. That sounds like the sort of thing someone with your experience could do, and you should be in a position to be realistic about your requirements as you already make real-world parts. Some people are more 'dreamers' expecting to come from zero experience making 'things' to turning out parts within 10 microns on a $1000 machine. I say go for it, and concentrate on doing what you need to get the parts that you want. On my conversion I have not scraped anything, it's a Chinese BF-30 type mill with steppers and ball screws. Not a hugely modified machine. I have replaced the spindle motor and done a belt drive conversion. The machine has made hundreds or thousands of parts and has tens of thousands of hours of run time on it. I spend much more time making parts than I do tweaking and modding the machine. So it can be done and can achieve what you want. Remember - threads here are often about problems people have and issues they need to sort, and of course the process of CNC conversion. You don't see many threads saying 'hey, look at the run of 50 great parts I just made on my Chinese benchtop!' because the people that do that are making parts and not modding their machines and posting on the forum.
LongRat
www.fulloption.co.uk
