Hi guys,
if all goes well, there should be a photo of my machine attached to this posting --- in which case this will also make a bit more sense
The machine started out as nothing more than a framework for an X-Y plotter as I wanted to do a study on motion control. However, as time went on and I kept playing with the AVRs, I got more and more ideas of what this framework could be so it has morphed into a CNC machining center for PCB work. Some of you may also recall a posting by me a few months back of the machine in it's earlier stages.
There are currently ten AVRs on this machine handling various tasks. All of these are ultimately controlled by the CNC control software running on a Windows PC.
The machine isn't done yet, probably never will be as I keep adding new toys, bells, and whistles to it as it is proving to be a great learning platform.
A brief overview of it's features
Full operator panel with many switches to control the running of the CNC program and to provide manual operation.
8" x 10" table travels
4" of Z axis travel
Stepper driven through leadscrews - .0001" resolution
Current maximum traverse speed is 110 inches per minute
Variable speed spindle 1500 ~ 7000 RPM
Maximum tool diameter - .150"
Automatic tool changing - uses a variety of sensors and a sepperate hi-torque spindle drive motor for clamping / unclamping
38 Tool capacity tool magazine (not functioning just yet)
Temperature monitoring of all critical elements - reported on LCD
All machine side electronics are interfaced to the host PC using USB-Serial adapters (FTDI)
Probably many other features and things too, but those are the major features.
Hope the photo posted so this all makes sense!
Chris
