586,499 active members*
2,727 visitors online*
Results 1 to 10 of 10
    Aug 2010
    7
    Red face Silly Question
    I have aquired a old cnc pick and place unit witch I intend to convert to 3D cnc / mill ?
    BUT it uses 2 sevo motors with encoders for one axis one on each side Attachment 248076
    Can I set up the artsoft to use two motors and encoders on one axis ?
    any advise thanks John
    Feb 2007
    711
    Re: Silly Question
    I think you are confusing artcam with mach3 (artsoft?)
    It can use 2 motors for 1 axis, I don't know if it will read the encoders or not.
    Dec 2003
    24223
    Re: Silly Question
    Look at Kflop and Kanalog if analog servo's.
    Al.
    Albert E.
    Aug 2010
    7
    Re: Silly Question
    Thanks for info will look into it ?
    Jan 2005
    15362
    Re: Silly Question
    wildrat
    If the servo drives that the machine has take step/dir then you can use Mach3, find out what Servo Drives/motors you have,also if the Encoders goes to the Servo Drive or to the control, this will tell us what you need to do
    Mactec54
    Aug 2010
    7
    Re: Silly Question
    will strip out and check but also has sony linear encoder/scales on all axis could this be used as well for feedback ? thanks john
    Dec 2010
    33
    Re: Silly Question
    Just slave the one motor off the other, the encoder is just feedback to keep the co-ordinates absolute,
    Ex Emach Service Engineer, contact me for assistance.
    Aug 2010
    7
    Re: Silly Question
    Ok have issue with servo drivers cannot get information on inputs or how to use as is proprietary for the machine maker and the manufacture will not give any details out?
    So considering replacing servos with steppers as servo drivers too expensive for 3 off
    Can anyone advise if the torque of 13 kg-cm on the servo motor would be measured the same way on a stepper motor or different?
    E.g. the servo is the max torque before stall and the stepper max holding torque as trying to find equivalent power!
    Thanks john
    Dec 2010
    33
    Re: Silly Question
    what is the make of the servo drivers?
    Aug 2010
    7
    Re: Silly Question
    Motors marked TS4047N116E31
    Drivers marked AU6310N2031
    All Tamagawa-Seiki
    Fitted to a Juki KE-710 pick and place unit ?
    Thanks john
    Attachment 248922
Name:	driver lable.jpg
Name:	TBL Driver.jpg
  1. Silly Question
    By Son of Aslan in forum Commercial CNC Wood Routers
    Last Post: 06-21-2012, 09:48 PM
  2. Silly Question
    By Smitty911 in forum Uncategorised CAD Discussion
    Last Post: 12-21-2010, 06:30 PM
  3. Silly Question
    By Smitty911 in forum CamBam
    Last Post: 02-11-2008, 10:30 AM
