586,283 active members*
4,012 visitors online*
Results 1 to 15 of 15
    Sep 2013
    12
    Free to use CAM software
    Hello everyone
    I just purchased a Makeblock XY drawing plotter and I need a CAM software to create simple 2D G-Code from 2D cad drawings so I can draw them out on the plotter. I have Rhino 4.0 for creating CAD drawings but I don't want to buy Rhinocam after already paying $900 Rhino. Can anyone recomend a decent free to use CAM software that I could import a 2D drawing into and then generate G-Code?
    Christine
    Jan 2014
    37
    Re: Free to use CAM software
    Sadly I do not know a free to use software, but FILOU NC is capable of importing 2D dxf files and it starts at about 170$
    Sep 2013
    12
    I have Mastercam at work that I use everyday but can't take it home. Guess I'll have to sneak in my plotter programming at work.
    Mar 2016
    1
    I've been getting acclimated with HeeksCAM. I have purchased the software (You might need a loan...about $13 US.) but you can run it free with easily surmountable limitations to make sure that it works with your machine. I believe that you can use it in Linux free but I'd recommend throwing Dan a donation if you like it as I'm sure he's got a lot of time in it. heeks.net
    Anyhow, it works nearly flawlessly with DXFs. You will find that there are fewer bugs when working in MM. Also you can tune it to your needs if you're somewhat savvy. I'm not a genius and figured out how to make it cooperate with the non-standard programming requirements of my Dynapath control. Specifically, I needed an absolute I,J rather than incremental. One word of caution is that if I and/or J are zero absolute it acts funny, so I moved my model away from the origin and all the troubles were gone. I was able to modify the emc2b.py and iso-read.py (renamed before saving) then added a new machine to machines.xml to accomplish this. I've still got to figure out how to make it put G and M codes on their own lines but I've just been editing that part manually in NCTerm before sending it to the machine. Documentation is a little lean but you can look through the python files to make it do just about anything you want. If you're not familiar with Python, search for "learn python the hard way" as there are some very good lessons there.
    35538
    g simple
    ace converter
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Dec 2007
    2134
    Christine, EstlCAM software developed by Christian Knull might interest you, it's pretty well featured and relatively easy tio use:
    Estlcam.de 2D / 3D CAM Software und CNC Steuerung...
    And for such a good package it's very affordable in my opinion, plus there is always support from the guy who created it.
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
    Dec 2007
    2134
    I forgot to add, EstlCAM is $50, which is pretty excellent I think, although it's not free, it's about as cheap as a package this good could possibly be.
    cheers, Ian
    May 2016
    6
    Hi to All!
    I use Estlcam to create the G-code for my machine controller. I also use my Shapes Plus program to create the DXF file to import to Estlcam.
    I recently seen a YouTube video from Estlcam, showing a vacuum pad. I thought would give it a try and design it in Shapes Plus.
    This Estlcam Vacuum Pad video
    https://youtu.be/5c_gM1_jDgY
    This the video of my try.
    https://youtu.be/ZjVrL3OKOtM
    Estlcam is free to use except it will pause sometimes.
    Shape Plus is still being developed.
    Cheers
    Bob Adams
    Jun 2012
    108
    I use Cambam free it is their 2007 Version. go to their download page and scroll down to the bottom of the page.
    http://www.cambam.co.uk/downloads/CamBam-beta0.8.2.msi
    Oct 2012
    193
    Here you can find and download CAM software for free. Ajan CNC Machines Software
    www.ajancnc.com
    May 2004
    35
    Mechsoft has a free 3-axis CAM program
    Free CAD/CAM Software Package from MecSoft Corporation
    Apr 2009
    5516
    You can't save your file as HPGL, which is readable by most all plotter drivers?
    Service SCM BR Guest
    Hi, what extension the estocam output? Xxl?
    May 2016
    6
    Estlcam outputs G-code for DXF,STL, and SVG.
    Mar 2014
    735
    EstlCam! :banana:
  1. Free CAD software
    By ynneb in forum Uncategorised CAM Discussion
    Last Post: 07-08-2011, 12:35 PM
  2. MIE Solutions - Free Quoting Software Trial Software available
    By MIE Solutions in forum News Announcements
    Last Post: 01-07-2009, 05:42 PM
  3. Free Doors--Free Cabinet Door Software
    By 1BigPig in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-07-2007, 07:36 PM
  4. First post in the software dept. Free cnc software?
    By runinbymdnt in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-07-2007, 04:49 AM
