586,145 active members*
3,616 visitors online*
    Dec 2013
    41
    Question Antek Power Supply Wiring?
    Hoping for a little help with how to wire my Antek 70v 1500W power supply to my PMDX-134. There are two sets of capacitors. Antek's website states to wire these in parallel to allow full current (each capacitor set 11A?). I'm slightly confused because each set of capacitors has screw terminals labeled "++C--". I'm not sure what the C is and I'm not sure why there are two terminals for the live and neutral wires. I know this should be simple, but I don't want to mess this up. Here is how I believe it should be wired. Could anyone confirm this:
    Feb 2007
    4553
    Re: Antek Power Supply Wiring?
    Quote Originally Posted by groc426 View Post
    Groc426,
    If you are connecting to J5 on the PMDX-134 your diagram is correct.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Dec 2013
    41
    Jeff,
    I sure am. Thank you for your quick response. I really appreciate it! I tested it out after your confirmation and works absolutely great. Thanks!
    Mar 2007
    2083
    Hi
    the power supply has 2 live and 2 neutral connections because the transformer has two 115v primary windings that can be wired in parallel for a 115V supply
    or in series for connection to a 230V supply
    the common "C" terminals are not conected in your version of power supply
    John
    Dec 2013
    41
    That makes sense. Thanks! This is all a learning experience, you guys are always so great to help.
  1. Antek Power supply and Granite drive issue
    By Dr.Nos in forum CNC Machine Related Electronics
    Last Post: 09-27-2013, 01:15 AM
  2. Grounding Antek power supply to equipment chassis?
    By wlwoodall in forum CNC Machine Related Electronics
    Last Post: 08-21-2010, 03:47 PM
  3. Wiring and Power Supply Help Please
    By ashjam in forum CNC Machine Related Electronics
    Last Post: 08-14-2010, 08:38 PM
  4. need help wiring power supply
    By timewarp in forum Automation Technology Products
    Last Post: 06-21-2010, 03:25 AM
  5. help wiring a power supply please..
    By justin2 in forum CNC Machine Related Electronics
    Last Post: 12-19-2008, 04:33 PM
