586,250 active members*
3,429 visitors online*
    Extraction to atmosphere help
    Hiya all
    I have a laser pro x252 that I use with a BOFA extraction unit. I cut mostly 2mm MDF/medite and I'm going through filter quite quickly and they are very expensive. I want to try extraction to atmosphere.
    My original plan was to extract to air with an Axminster Hobby series AWDE5002. I never used it with the supplied bag but ran it with some ducting out of window but it never worked well at all and the laser (and workshop!) soon filled with fumes.
    I want to explore extracting to air again and would really like some advice about choice of extractor unit. Ideally a quite extractor that doesn't require three phase would be great.
    Thank you.
    Nige.
    www.timelineminiatures.co.uk
    Jul 2014
    19
    Re: Extraction to atmosphere help
    I don't know the exact english translation, but I use a tube-mounted ventilator.
    Attached there isa big carbon filter. Both the filter and ventilator I bought in the Netherlands at a homegrow shop..
    works pretty good and silent!
    Hi laserMark,
    Thanks, I'm trying to avoid getting a solution with a filter to keep the price down
    Nige.
    Nov 2012
    492
    you might look into a large bilge blower, their cheap and noisy but they pull a lot of air. I use one on my laser works well.
    https://www.google.com/search?q=larg...x-a&channel=sb
    Hiya Bigbird48,
    Thanks! I'd not heard of these so I'll check them out, thank you.
    Nige.
    Nov 2012
    492
    let us know what you do and how it works for you:cheers:
  1. extraction systems
    By mindmapper1 in forum Laser Hardware
    Last Post: 07-31-2013, 03:56 PM
  2. Extraction Issue on SCM 132
    By fegt in forum Safety Zone
    Last Post: 01-27-2011, 06:05 PM
  3. Air extraction once more - best project I seen
    By Litografa in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-09-2010, 03:00 PM
  4. Extraction advice
    By McIntyre in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-28-2010, 06:09 PM
