586,398 active members*
3,088 visitors online*
    Mar 2009
    18
    Fixed Drilling problems
    Run a Daewoo puma 250. using kenametal fixed index drills to drill holes. drills fine most of time but sometimes I think i'm not exactly drilling on center. leaves a nipple inside of hole. changing drill inserts often especially the inboard tool. what can be done to know that i'm exactly on center?? usually happens with smaller diameter holes such as .500 .625 .750 all the way to 1.0 the 1 inch diameter holes and up to 2.125 holes seem to drill alot better. ????
    Jul 2004
    239
    Re: Fixed Drilling problems
    Is is possible that the drill's you are using, are not meant to do the complete hole, all at once. You may need to do these hole in two or three steps... so the final hole is more accurate.
    I would research the companies documentation, and verify you are using them correctly. They may work, like your using them, but may not be meant to do so.
    Years ago, when we ran the big spade drills on the Warner Swassy's... we would always step up, at least for the start of the hole. 2.5" drill, we would use a 7/8" pilot...
    Also on very tight tolerance, we would go in with a boring bar after.
    _______________________
    Otherwise, cannot you measure the accuracy of your parts? The question seems funny, for that reason. Could not you measure the part at the bottom of the hole, and at the entrance, and see if it is wondering? As well the wall thickness, all the way around.
    If your machine is older, you may find you have to change your practices or routines, as the machine start to wear, and is not as accurate as it was when new. You may have something beyond the part that is giving you trouble, during heavy cuts.
    Robot & Machine Design - BLUECNC4, GreenCNC3, RedCNC2L, SilverCNC2; CNC Software!
    www.truemachinedesign.com - - - - - - - - - - - - - www.truemachineautomation.com
    Feb 2013
    788
    To check turret to Chuck center, use a coaxial indicator.
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
  1. Surfacefinish problems help drilling
    By charlieslasher in forum Uncategorised MetalWorking Machines
    Last Post: 06-25-2014, 02:11 PM
  2. Problems with drilling
    By skylanehku in forum Mach Mill
    Last Post: 08-12-2013, 06:58 PM
  3. EDIT: ALL FIXED... DISREGARD!!! New CNC machine problems
    By Atomic_Sheep3 in forum Benchtop Machines
    Last Post: 09-29-2011, 03:36 PM
  4. drilling hole problems
    By mathewepperson in forum Haas Mills
    Last Post: 06-16-2011, 06:14 PM
  5. problems drilling small holes in G10
    By kentw in forum Composites, Exotic Metals etc
    Last Post: 05-10-2011, 08:21 PM
