587,004 active members*
2,768 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > PLEASE HELP: Rotary Feature must wrap around Z axis problem
    Dec 2013
    27
    I'm trying to define a rotary mill feature but no matter how I align the Z-Axis, I receive this error message (see image). I've tried every which way. Can anyone offer any suggestions?
    Attachment 247760
    Oct 2009
    47
    Re: PLEASE HELP: Rotary Feature must wrap around Z axis problem
    The message "Rotary Feature must wrap around Z axis of current CPL" indicates that the centerline of the rotary face is not coincident with the centerline. My suggestion would be to use the Verify Entity command to determine where the centerline of the face is, and then make necessary adjustments. The adjustment could be moving the part to the correct position, or editing the CPL.
    Dec 2013
    27
    Quote Originally Posted by jsanders View Post
    Thanks so much, Jsanders. That was exactly the issue! I assumed that importing parts from Autodesk Inventor would line up center points accurately with Edgecam but the Verify Entity showed my X plane was 0.8mm off! So strange on such a simple cylinder... after I manually shifted the CPL over, I was able to pick the rotary feature easily.
    Thanks again!
  1. NEED HELP ON MILLTURN WRAP FEATURE
    By plast744 in forum CamWorks
    Last Post: 12-09-2014, 12:40 PM
  2. V25 Rotary Axis problem
    By ShortTrack in forum BobCad-Cam
    Last Post: 07-16-2014, 02:32 AM
  3. G93 4th axis rotary problem
    By Aionerv in forum Fagor Automation
    Last Post: 02-05-2013, 04:45 PM
  4. Mastercam rotary axis problem
    By squirrel_41 in forum Mastercam
    Last Post: 06-29-2012, 06:47 PM
  5. Mastercam rotary axis problem
    Last Post: 06-02-2012, 02:26 PM
