586,401 active members*
3,019 visitors online*
Thread: Surface Cut?
Results 1 to 2 of 2
    Apr 2006
    822
    Surface Cut?
    Hi all,
    Have this job where we have been asked to modify some drill heads, fine tuning the profile and position of the cutting edges.
    Have no problem modelling the majority of the head, but when I got to the profile area behind the cutting edge, I became stumped.
    I have been trying to use a surface fill between the two projected curves forming the boundary of the area I wish to remove, but everything I try fails to give anything like the surface I want.
    I was then going to use a surface cut to achieve the final profile.
    Really need to figure out how to get this modeled as once the first drill head is done, then there are more to follow...
    Can anyone help?
    I have attached a photo of the original sample and the model as completed so far.
    Thanks in advance.
    Brian.
    Attached Files Attached Files
    Apr 2006
    822
    Re: Surface Cut?
    Problem solved, used a multipart Lofted Surface to get what I wanted.
  1. 3D Surface Toolpath milling deeper than surface
    By moto1965 in forum Mastercam
    Last Post: 07-30-2014, 04:15 PM
  2. Surface over a surface problem
    By omnitech in forum FeatureCAM CAD/CAM
    Last Post: 10-20-2011, 03:42 PM
  3. Fillet surface to surface problem
    By vincent13 in forum Mastercam
    Last Post: 02-10-2011, 01:15 PM
  4. MX3 SURFACE TO SURFACE TRIM
    By 82rouled in forum Mastercam
    Last Post: 05-18-2009, 06:02 PM
  5. Surface to Surface Filleting and Trimming
    By cowpoke in forum Mastercam
    Last Post: 03-17-2009, 02:42 PM
