586,398 active members*
2,977 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Z axis peck drill program on Fanuc OT controller
    May 2008
    107
    Dear all.
    Does any one worked on Fanuc OA-T controller? I need Z axis peck drill program, but the controller not alowed G83 or G75( even 74).
    Thanks for your help.
    Aug 2011
    2517
    Re: Z axis peck drill program on Fanuc OT controller
    G1 Z-1.0
    G0 Z0
    G1 Z-2.0
    G0 Z0
    G1 Z-3.0
    G0 Z0
    etc etc etc
    or use sub program with incremental movement and L repeat
    example below will peck 30mm deep from start point Z0.5
    Peck is 2.0mm but back-off is 0.5mm so actual peck is 1.5mm
    and 1.5 * 20 repeats = 30mm depth
    G0 X0 Z1.0
    G1 Z0.5
    M98 P0002 L20
    G0 Z0
    O0002
    G1 W-2.0
    G0 W0.5
    M99
    May 2008
    107
    Dear fordav11: Thanks so much for your reply.
    I fixed it already: Just because one option parameter was not open: The parameter #901.7=0, then all canned cycles is disabled. Evevy thing OK now.
  1. G83 Peck Drill on Fanuc 18-T
    By JerryH in forum G-Code Programing
    Last Post: 06-13-2011, 01:32 AM
  2. Dyna Delta20 Peck Drill Program
    By dingo0722 in forum Dynapath
    Last Post: 09-29-2010, 01:21 AM
  3. Dynapath delta 20 Peck drill program
    By dingo0722 in forum DynaCNC
    Last Post: 09-10-2010, 04:37 PM
  4. Fanuc 31i Hi speed vs Peck drill parameter
    By Kennebec in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-04-2008, 02:33 PM
  5. To Peck drill or not to peck dril.....
    By Crashmaster in forum MetalWork Discussion
    Last Post: 08-23-2008, 05:33 PM
