586,538 active members*
3,003 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > PlasmaCam > I NEED HELP WITH GENERAL PLASMACAM SETTINGS, ROUGH CUTS, SPRAW AND LARGE PIERCE HOLE
    Oct 2012
    22
    Hello
    I have a plasmacam problem. I have had unit in shop for years and used to cut some rough parts. Now I want to do some more precise detail work and cannot get the unit dialed in. I am at my whits end and have spent a couple hours trying to get it to get it cut a clean part. No luck.
    I am cutting a new piece of 1/8" steel .131 10ga. It always pierces and makes a large hole then the cut is always jagged with lots of spraw. I am sure someone has someone has the settings and can help me out. I'm sure several of my settings are off, from psi to speeds.
    Thanks for reading my post.
    Jc
    AIR PRESSURE 120 PSI
    HYPOTHERM POWERMAX 85 SET AT 75AMP
    STANDARD ELECTRODE AND NOZZLE THAT CAME WITH UNIT, I HAVEN'T CHANGED.
    ### PLASMACAM HEIGHT CONTROL IN SETUP SCREEN
    Z AXIS MOTION
    Z SPEED AXIS 104.5
    X RAISE AND LOWER BETWEEN CUTS
    HEIGHT FOR RAPID TRAVEL 0.5
    HEIGHT FOR PIERCE (INCH) 0.5
    X SENSE MATERIAL TO SET HEIGHT
    OVERALL FOR SENSE (INCH) 1
    MATERIAL THICKNESS INCH/GA 10
    DIGITAL HEIGHT CONTROL
    X USE TORCH HEIGHT CONTROL
    CUTTING HEIGHT (INCH) .5
    Z AXIS CALIBRATION
    ARC VOLTAGE SHIFT (INCH) 1
    Z SHIFT (INCH) 0
    ### MACHINE CONTROL IN SETUP SCREEN
    RAPID TRAVEL SPEED (INCH/MIN) 1000
    RAPID TRAVEL ACCELERATOR (G) .1
    PAUSE BEFORE RAPID TRAVEL
    CUTTING SPEED (INCH/MIN) 50
    CORNER ACCELERATOR (G) .1
    SLOWER ON CIRCLES INDER (INCH) 0
    PAUSE BEFORE CUTTING
    RAPID TO HOME AFTER CUTTING
    TIME DELAYS
    X WAIT FOR CUTTING SIGNAL BEFORE MOVING
    TIME SPENT PIERCING HOLE (SEC) .5
    CONTINUE CUTTING AFTER STOP (SEC) .05
    TORCH LOCATION ADJUSTMENT
    X SHIFT (INCH 0
    Y SHIFT (INCH) 0
    Sep 2014
    112
    Cool Re: I NEED HELP WITH GENERAL PLASMACAM SETTINGS, ROUGH CUTS, SPRAW AND LARGE PIERCE
    Hey Union Outfitt!!
    I hope that you are having an awesome Labor Day! Check out the settings listed below (this is exactly what I use) and you'll be cutting 10 ga perfectly in no time!
    Also, you definitely want these 45-Amp fine cut consumables (optimal for clean cuts w/ narrow kerf):
    Attachment 248032
    If you have if you have the advanced HC get the "Ohmic -Mechanized'.
    Machine Control:[/U][/B]:
    Attachment 248034
    Height Control:[/U][/B]:
    Attachment 248036
    Attachment 248038
    Happy labor day and enjoy!
    Jasper
  1. PlasmaCam settings
    By Tobiwan in forum PlasmaCam
    Last Post: 04-08-2013, 05:22 PM
  2. Sheetcam Wiggle pierce Settings.
    By rescueweasel in forum SheetCam
    Last Post: 10-12-2010, 06:13 AM
  3. pierce hole?
    By slammedxonair in forum DynaTorch
    Last Post: 05-11-2009, 03:12 AM
  4. Pierce delay and plunge rate settings.
    By Fiero Addiction in forum Waterjet General Topics
    Last Post: 07-20-2008, 12:05 AM
  5. pierce for center of hole
    By bearracecars in forum Waterjet General Topics
    Last Post: 09-01-2007, 04:46 AM
