586,409 active members*
2,915 visitors online*
    Aug 2014
    8
    Moshidraw 2014 Just stops half wa through
    Well it looks like I got the issues takes care of with the calabration of the laser and I am now able to engrave.
    I and importing jpg files I put together in Photoshop so This is working. But sometimes the laser stops half way and I am stuck in a pattern.
    Not sure if this is due to the laser getting to hot? I have chilled water in the cooler that I am using to pump through the laser. how cold does it need to be? Maybe this is the issue.
    Also when I set the laser to cut Moshidraw 2014 does not work at all. any luck?
    -J
    May 2010
    41
    Re: Moshidraw 2014 Just stops half wa through
    So laser stops engraving/cutting while the program and machine keeps running?
    Or the machine engraves/cuts and halfway through, everything stops and goes back to home?
    KL-4530 CNC, KL-6060, 5 3D printers, CNC Fusion Converted LMS Milling Machine, 60w Laser Cutter
    Aug 2014
    8
    The laser stops engraving and stays in place and does not go to home.
    In MoshiDraw 2014 the status of the laser is closed.
    I've found moshi will do that on larger engraves, It's not the greatest software unfortunately. I just do it over til it works when it does that, or adjust the amount of data going to the laser by changing the engrave settings to a coarser cut
    Aug 2014
    8
    Is there a better controller board I can switch to and get away from MoshiDraw all together?
    yeah if you're usa side, check out California Sacramento CO2 laser engraving cutting machine & Parts. Purchase or rental. Electronics Supplier in Northern California for PID temperature controller,brushless dc water pump,laser controller,laser power supply
    Laser & CNC has a lot of upgrades, a lot of people switch to the 608 for the k40, lasercut is better, still has issues but its more reliable. if not usa, i'd probably look into just going to alibaba/ebay to get the same controller.
  1. Can anybody help me with Moshidraw Please?
    By Ranscon in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-10-2014, 06:57 PM
  2. Y axis stepper stops moving half way through cycle
    By pumpercloggs in forum Syil Products
    Last Post: 06-15-2013, 10:49 PM
  3. Laser stops moving and burning half way
    By CARTOGATE in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-28-2008, 03:46 PM
  4. Replies: 0
    Last Post: 06-30-2007, 10:13 PM
