586,414 active members*
3,200 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > How do you make different H-Class threads with a thread mill.
Results 1 to 7 of 7
    Jun 2012
    19
    I'm using a threadmill on a cnc machine and trying to make a 1 3/16"-16 internal thread at H11 Tolerance. Do I just make the major diameter larger? this is something that is new and confusing to me. I have read up on H tolerances but I guess not good enough.. If anyone can relate to this or can explain how to do this that would be great.
    Oct 2013
    64
    Re: How do you make different H-Class threads with a thread mill.
    You should make it 0.016 smaller. What kind of matirial you are using?
    Oct 2013
    64
    0.016 smaller.
    Oct 2013
    64
    Sorry. 0.016 mm smaller.
    Jun 2012
    19
    Thanks for the reply, I'm using 6061 and 7075 Aluminum
    Jun 2012
    19
    Wouldn't I make the threads larger because its an internal thread?
    Dec 2008
    3111
    For a Ø1.1875" ( Ø30.163mm ) with H11 tolerance
    H11 tolerance on Ø30 to 50mm range is +160μm to 0μm....... Hole basis chart link
    0.160mm = 0.0063"
    so then your nominal pitch diameter is Pd=D-(0.6495/TPI)....=...1.1875-(0.6495/16)....=....1.1469....this is your lower limit
    upper limit is 1.1469+0.0063 = 1.1532"
    If you wanted to do it correctly, you may wish to make GO-NOGO gauges,
    --- turn 2 external threads to the correct pitch diameter....your GO must screw in to full depth,,,.the NO-GO can start by 1-2 turns, but not be able to screw in at all
    I would program to nominal size, and adjust the tool offset in the machine to get finish size.....make the tool smaller to cut the thread larger
  1. how to make NPT threads in Mazatrol Matrix
    By klzz in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-11-2022, 11:54 AM
  2. how to thread mic acme threads
    By redridertwo in forum MetalWork Discussion
    Last Post: 05-30-2014, 01:23 PM
  3. How to make acme threads?
    By MPI-Ferrari in forum CamWorks
    Last Post: 08-21-2012, 07:59 PM
  4. How do I make threads on my Sieg C4?
    By Blakelidge in forum Mini Lathe
    Last Post: 07-30-2011, 06:52 PM
