586,401 active members*
2,923 visitors online*
Results 1 to 4 of 4
    Jan 2013
    V2XT error code - 1
    Hello and Help, I have a Bridgeport V2XTand when I boot it up I go into Machine Check and it fails. I then get an Executive load- Failed - error code - 1.
    So what is an Error code 1???
    Nov 2004
    3028
    Does this machine have a FMDC? Is it booting from the floppy? Is the CMOS correct? Is it a good floppy?
    George
    Jan 2013
    Thanks for responding.
    Yes, it has an FMDC.
    Yes, I do believe it is booting for disk. - Whwn I turn the machine on I get :Invalid Configurationinformation - please run setup program
    : Diskette drive 1 seek failure
    : Strike the F1 key to continue, F2 torun the setup Utility
    I hit F1 and it goes to BOSS XT
    Then - Machine Check..Failed
    Then - Executive Load..Failed - error code - 1
    Then - A:/>
    Feb 2014
    2
    Re: V2XT error code - 1
    Quote Originally Posted by machintek View Post
    George
    I have got it to load once or twice But now It won't. I've tried every boot disk off this site and any other on I can find. Also have tried dos 5.0 and 6.2. It's a fdmc unit with 4 aa's battery. they went dead and I replaced them but not wile under power. I had it load 2 or 3 times after that but I tried it a week later with no luck since. The disk that tries the hardest is the dx32 one off this group dl's it runs about 2 pages of code then pops back to a: * It has a 486 motherboard and a hard drive or a c: which I believe is on the communication board in a big slot on the mother*
    thanks for any input
  1. g code error with image to g-code
    By cruzin in forum LinuxCNC (formerly EMC2)
    Last Post: 09-05-2012, 11:34 PM
  2. Error code 104
    By morpwr in forum Haas Mills
    Last Post: 10-27-2011, 03:37 AM
  3. V2XT error message "DRIVE FAULT detected (0,z,y,x) check log"
    By rfdoyle in forum Bridgeport / Hardinge Mills
    Last Post: 10-08-2007, 09:35 PM
  4. V2XT startup fail error-1
    By photoron2 in forum Bridgeport / Hardinge Mills
    Last Post: 10-05-2006, 05:21 PM
  5. V2XT Z overflow error
    By Lasershop in forum Bridgeport / Hardinge Mills
    Last Post: 01-12-2006, 11:05 PM
