586,224 active members*
3,179 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > MV-Junior 4th axis not going to programmed degree
    Jun 2013
    14
    Our new to us MV-Jr with fanuc 10m controller doesn't go to 45 degrees if you program it to do so. It's about 34 degrees. I think there is a parameter that is not set correctly. It's like the machine thinks one revolution of the 4th axis (a) is 39* degrees instead of 360. Any help would be appreciated. thanks
    Dec 2009
    539
    Re: MV-Junior 4th axis not going to programmed degree
    Hello,
    what if you do 90 degrees, does it got to actual 68? And what if you command 45 degrees, and then tell it to -45 degrees, does it return exactly to where it should?
    John
    Jun 2013
    14
    If you program any degree in any direction it runs short of the actual angle. It thinks there is 392 degrees in a rotation..
    Has this ever worked on this machine? I would first verify that the coupling is not slipping. The find out how many pulses your motor encoder has. Then you need to set parameter 1816 to match that encoder.
  1. Replies: 9
    Last Post: 06-05-2014, 04:41 AM
  2. stop c axis at specific degree
    By tkimdy in forum Okuma
    Last Post: 09-27-2013, 09:32 AM
  3. 4th axis 90 degree mount???
    By compunerdy in forum Tormach Personal CNC Mill
    Last Post: 12-18-2009, 05:13 PM
  4. Replies: 3
    Last Post: 06-30-2008, 01:30 AM
  5. Y axis moving without being programmed HMB-1
    By carbidecraters in forum HURCO
    Last Post: 06-22-2008, 06:51 PM
