Hi does anyone have a link to Corel draw for a download and will I need a USB key
Corel Draw is a pay for program. The best place to get it is on EBAY. You can probably get the student (academic) version for around $60 to over $100.00 depending on the version. Is that what is happening for you? I mean, is the program that you have for your laser asking for Corel Draw to be installed? This is common.
Milt
Yes I think that could be the answer that I need Corel draw to be installed
Then the only option is to buy a copy of the program. As I stated above, you can get an academic copy on ebay that should work, but I am just guessing. I purchased the full copy, that will set you back a couple of hundred, I think.
Milt
Corel Draw Home and Student edition does not allow macros so you cannot use it for the laser plug-in (at least for X6). Didn't find that out until after purchase unfortunately.
