586,512 active members*
3,295 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > Milling foam rubber - which tools ?
    Aug 2010
    25
    Hello,
    i am trying to find the right end mill for cutting soft foam sheets. I'm not sure what the exact material is, in Germany different variants of this material go under the name of "Schaumstoff", Wikipedia says it's called 'Foam Rubber' in English, Google translates it as 'Foam material'.
    I have tried out different types of end mills and so far the best result is with a 5 flute new and ultrasharp bit ... 1, 2 flute and 3 flute don't work so well but at the moment i don't have any new super sharp ones.
    heres one of the tests i did, it's usable but i'm really looking for a much better finish.
    Attachment 247176
    Attachment 247178
    Attachment 247180
    Attachment 247182
    The guys i usually buy my tools from have a new type of mill specially for this material:
    Schaumstofffräser von DATRON - YouTube
    but they're quite expensive and the type of foam they're cutting in this video is much denser than the one i want to use.
    Does anyone have any experience with this type of material ?
    Jun 2009
    195
    Re: Milling foam rubber - which tools ?
    looks like polyethylene foam and best water jetting it or hotwire cutting . also the density on what datron is using is higher than what you're working with .
    tony
    Jun 2014
    39
    that looks like foam rubber. Hot wire it, don't mill it.
  1. Grinding or milling a pocket in 40 durometer urethane rubber
    By bildoo in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 05-02-2010, 06:30 PM
  2. Milling Foam
    By apeman88 in forum Tormach Personal CNC Mill
    Last Post: 07-07-2008, 09:23 AM
  3. Best Way To Cut Rubber With Hand Power Tools
    By lostbaka in forum Material Machining Solutions
    Last Post: 03-09-2008, 05:27 AM
  4. Sponge Rubber and Diamond plate looking rubber?
    By DennisCNC in forum Community Club House
    Last Post: 06-01-2007, 06:15 PM
  5. What is the best router to cut this foam/rubber?
    By Darc in forum DIY CNC Router Table Machines
    Last Post: 08-28-2005, 02:39 AM
