A bit about bits ? (Bobart ver25)
I have a question about what bit would be a good choice for pocketing in the V-carving routine.When you do v-carving you are given the option to use a different bit to pocket with.
Would and up-cut or down-cut be the better choice. You want to get a good flat clean bottom.Will a 0 flute 2,3 or 4 flute be the better choice. You also want good clean edges.
I will be buying some bits for just this operation and want to get the right ones. SSI don't have money to waste. LoL
2nd question about V-carving. Some of the settings are not explained to well as to what they do.Is there a good Tutorial for V-carving that goes into detail about the settings.What
effect they have on each other and the project overall.
Thank You
Don
The time has come the woodworker said to speak of many things. 0f routers and Wood , chips and paints and stains and CNC and other things.
