586,160 active members*
3,476 visitors online*
Results 1 to 5 of 5
    Mar 2010
    813
    When Jogging it wont exceed past 200ipm!
    Hello all, really need some help! I goggled and searched but couldn't find a solution. When in motor tuning I'm able to jog at maximum(Velocity set at 1200ipm), but once I leave motor tuning it won't jog past 200ipm. I have jog set at 100%. I was hesitant to post because thought was a simple setting but been trying to find problem for hours with no success.
    Appreciate any help or a point in direction to look.
    Thanks,
    Dan
    35538
    Re: When Jogging it wont exceed past 200ipm!
    Try turning off the toolpath and see if it helps.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2010
    813
    Hi Gerry, appreciate you quick reply. Using 2010 screenset, would you mind telling me how to do that? Would really appreciate it, going at this all day and having a brain freeze when looking at Mach screen.
    Thanks again,
    Dan
    35538
    Click the icon in the toolbar with the black and white square, 6th one from the left.
    Gerry
    Mar 2010
    813
    Thank you Gerry but that wasn't the problem, but looking at it with a clear head this morning found what it was by simply checking diagnostic screen. Due to my rebuild I have limit/home switches connected to BOB but not machine, 1 of them the wire pulled off and made and open connection.
    Must be really frustrating for you helping us noobs...lol
    Thanks again,
    Dan
  1. Replies: 7
    Last Post: 04-06-2014, 12:07 AM
  2. QT150 alarm 272 turret index exceed time
    By vinch9292 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-23-2012, 03:43 AM
  3. Following Error Limit Exceed - Cannot enable drives thru BOSS
    By gadgetwzrd in forum Bridgeport / Hardinge Mills
    Last Post: 02-09-2011, 02:39 AM
  4. Replies: 3
    Last Post: 04-29-2010, 06:41 PM
  5. Cannot go past 50 ipm!
    By greenene in forum Controller & Computer Solutions
    Last Post: 11-04-2008, 10:37 PM
