586,497 active members*
3,349 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Auxiliary axis to through RS232 on Haas Mini-mill
    Aug 2014
    Hi all,
    I am trying to use a haas servo controller and haas indexer (HA5C) to make a semi-fourth axis on a mini-mill. I plugged the servo controller into the mill via straight through RS232 cable. Tried changing setting 38 (Aux axis number) on the mill to 1 and it gave an error saying that there was no aux axis connected. I know I can wire the servo controller via the relay and use M-codes to index, but I would like to be able to program it more in depth through the code. I am not sure what to do....
    Apr 2010
    6
    Re: Auxiliary axis to through RS232 on Haas Mini-mill
    Quote Originally Posted by jstrong012 View Post
    Hi all,
    I know this is an old thread but, were you able to make it work? I want to do the same thing but, with a 2012 VF-2 and Servo Control
    Oct 2019
    Hi any news about that thread? i know it has been 10 years... but i am triying to do it on a VF2 2012 .. any notices? Thank you!
  1. Mastercam X4 to RS232 Haas Mill
    By DaOne in forum Mastercam
    Last Post: 02-03-2010, 04:59 AM
  2. Haas Super Mini-Mill and Haas Trunnion Table
    By Gabe Newell in forum Haas Mills
    Last Post: 06-07-2009, 07:23 PM
