Hello!
We are setting up our newly purchased laser from Automation Technology Inc and I have a few questions that I hope y'all might be able to help me with. The instruction manual is a little bit hard to read in places.
CO2 Laser Cutter and Engraver With Auto Focus, 60W, 20? X 12? | Automation Technology Inc
NOTE: Not shown (8 foot copper covered ground pole and grounding wire connected to machine).
QUESTIONS
1) Why is the third wire spliced off on the exhaust fan? (see image 1 & 2)
2) Is the foam in the laser compartment for shipping and needs to be removed, or does it stay in there? (see image 4)
3) Do I need to get a water tank for the water pump to go into to pump water TO the chiller then TO the laser and back again. How many gallons should this water tank be? (see image "setup") Would a plastic box with lid with holes cut into the top work for this? Any additional tips?
4)Signal cable between chiller and laser was missing a small screw. repaired is as shown in image "signal cable chiller to laser1") is this good?
Check out my ****ing awesome diagram. Is this what we want? Is a 30 gallon plastic container with holes drilled in the top sufficient?
THANK YOU!
Attachment 246726Attachment 246728Attachment 246730Attachment 246732Attachment 246736
