586,103 active members*
3,804 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > Epoxy Mortar or Grout CNC built
    May 2007
    42
    Smile Epoxy Mortar or Grout CNC built
    Hello everyone,
    I have started building a CNC based on commercially available epoxy grout ( 3 part ), the output looks okay and no cracking or stuff so far. Finished the Y-Axis
    Pictures
    Attached Thumbnails Attached Thumbnails CNC-Assembly-2-Final.jpg   cnc-y-bed-v1.2.jpg   CNC-Y-Bed-V1.2-mould.jpg
    May 2007
    42
    Re: Epoxy Mortar or Grout CNC built
    Mould and finished part pictures.
    May 2007
    42
    Jun 2013
    1041
    So far this looks very good. Great job! The built in oil ports are a great idea. Keep posting updates.
    Ben
    Apr 2009
    28
    It is a good job!
    Can you give more details about your mix?
    May 2007
    42
    Hello gozo
    Sorry for the delayed reply here are the details.Please see link. (this stuff is readily available per-packed as epoxy mortar or grout) and no vibration or ramming was done, used cement trowel to fill corners.
    http://assets.master-builders-soluti...w_410%20v1.pdf
    Bye
    Sahil
  1. A new epoxy granite CNC
    By muppy in forum Epoxy Granite
    Last Post: 07-02-2015, 11:46 AM
  2. epoxy with T-nuts ?
    By PaulRowntree in forum DIY CNC Router Table Machines
    Last Post: 10-30-2012, 01:55 PM
  3. epoxy granite
    By bebob1 in forum DIY CNC Router Table Machines
    Last Post: 10-30-2012, 11:25 AM
  4. Epoxy metal?
    By judleroy in forum Epoxy Granite
    Last Post: 03-19-2012, 11:27 PM
  5. Epoxy granite
    By slektning in forum Norwegian
    Last Post: 06-29-2011, 08:57 AM
