586,807 active members*
8,128 visitors online*
Results 1 to 14 of 14
    Jul 2005
    18
    Question Thread Milling 3/8-18 NPT
    Does anyone have an incremental program for a 3/8-18 NPT using a multi tooth threading tool. The diameter of my tool is .371". I am using a Tool Flo tool.
    Jun 2006
    478
    Try this...BE CARFUL! this is for a .31 dia. thrd mill but should work if you add .035" to cutter comp offset #1 (D1)
    O151
    (NO TOOL RADIUS COMPENSATION D1=0)
    (ADJ. D1 PLUS .035 AND WORK TO SIZE)
    N1 T1 M6
    G90 G0 G54 G17 X0.0000 Y0.0000 S???? M03
    G43 H1 Z1.
    Z0
    G01 G91 Z-0.4149 F200. M08
    G01 G41 D1 X0.0839 Y-0.0839 F??
    G03 X0.0839 Y0.0839 Z0.0069 I0.00000 J0.08390 F??
    G03 X-0.1678 Y0.1682 Z0.0139 I-0.16823 J0.00000
    G03 X-0.1687 Y-0.1682 Z0.0139 I0.00000 J-0.16866
    G03 X0.1687 Y-0.1691 Z0.0139 I0.16909 J0.00000
    G03 X0.1695 Y0.1691 Z0.0139 I0.00000 J0.16953
    G03 X-0.0848 Y0.0848 Z0.0069 I-0.08476 J0.00000
    G01 G40 X-0.0848 Y-0.0848 F200.
    G01 Z0.5417
    X0.0000 Y0.0000 Z1.
    M30
    Jul 2005
    18
    Thank you very much worked perfect. I ended up at .021 in the offset but it worked great. My only question would be the depth? .4149 seems kind of Shallow. I run my 1/4-18 NPT@ z-.522? Since the program is incremental could I drop the Z lower and just increase my D offset to compensate?
    Jun 2006
    478
    Yes, by all means , if you need more thrds. do exactly that. BTW, that came from a cd-rom I got from my Iscar rep. if you have one in your area he/she should be able to set you up with one. Its "geared" for there product line but, I've found it works well for others as well
    Jul 2005
    18
    Oh ok. Thanks again. We dont deal much with them but I will give it a shot.
    Jun 2006
    478
    One other thing, the cutting length of your tool would be the determining factor as to how deep you can thrd. mill. I have a prog. for a 1-11.5 NPT that cuts the hole with a .625 dia bull nose e.m. using virtual axis interpolation to put a chamfer on the tappered hole before thrd. milling it. Note speed and feed on the bull mill it has cut at least 350 holes and shows no signs of wear!
    M1
    M6
    G90 B90000 M42
    T76 S5000 M3
    (TOOL-94 = .625 BULL MULTI MASTER)
    (B90 DEG/ G54)
    G0 G90 G17 G95 G54 X-2.75 Y-3.5
    Z1. M8
    Z.1
    G91 G1 G95 F.02 Y.5488
    G3.1 X0 Y-.2713 J-.5488 Z-.3 P10
    G3.1 X0 Y-.0375 J-.2775 Z-.65 P18
    G3 J-.2485
    G1 Y-.2485
    G90 G0 Z1.
    X-4.75 Y0
    Z.1
    G91 G1 G95 Y.5488
    G3.1 X0 Y-.0375 J-.2775 Z-1. P18
    G3 J-.24
    G1 Y-.24
    G90 G0 Z1.
    G91 G30 Z0
    G30 X0 Y0
    M1
    (TOOL-95 = ISCAR THRD MILL .625 DIA./.08696 PITCH)
    M6
    G90 G0 G54 X-2.75 Y-3.5 Z1.9685 S3033 M03
    Z1. M8
    Z0
    G01 G91 Z-0.7339 F196.8 M08
    G91 G94 G01 G41 D1 X0.3067 Y-0.3067 F56.5
    G03 X0.3067 Y0.3067 Z0.0109 I0.00000 J0.30674 F38
    G03 X-0.6135 Y0.6142 Z0.0217 I-0.61417 J0.00000
    G03 X-0.6148 Y-0.6142 Z0.0217 I0.00000 J-0.61484
    G03 X0.6148 Y-0.6155 Z0.0217 I0.61552 J0.00000
    G03 X0.6162 Y0.6155 Z0.0217 I0.00000 J0.61620
    G03 X-0.3081 Y0.3081 Z0.0109 I-0.3081 J0.00000
    G01 G40 X-0.3081 Y-0.3081 F196.8
    G00 G90 Z1.
    G90 G0 Z1.
    G91 G30 Z0
    G30 X0 Y0
    Jul 2005
    18
    Wow that’s pretty impressive. What material are you cutting? We specialize in plastic so we never even cut a taper for an NPT thread on the mills. We just use the recommended size on a drill chart. But like I said that’s plastic. Now on a lathe it’s different we always turn or bore the correct taper.
    Jun 2006
    478
    Class 30 gray iron. We rarely taper ream either, I was just learn'in/play'in with the G3.1 virtual axis function on our new Mazak FH8800 machining ctr.
    Jul 2005
    18
    yeah you threw me for a loop I had never even seen a G3.1 before Mazak has their own controls right? We use Fanuc we have a couple of Haas' a Fadal and a couple of older smaller machinig centers.
    Jul 2003
    1220
    Is boring the tapered hole a problem if you don't have a reamer?
    I have a program that can generate a helix path to cut the taper. If a chamfer is required this can be generated and added.
    The program is listed here.
    http://www.cnczone.com/forums/showth...404#post190404
    Just ask if more info required.
    Jun 2006
    478
    Quote Originally Posted by shawn
    Mazak does have their own controls but as an option they can use "G-code" as well. If I'm not mistaken Fanuc has somthing like G3.1 probably an option though
    Jun 2006
    478
    Quote Originally Posted by Kiwi
    Cool prog. how do tell it different dia. tools or do you just use cutter comp.?
    Jul 2003
    1220
    ajl6549
    A drawing will need to be done to establish the start and end coords.
    The pics below show how this can be done for a tapered hole with a countersink.
    This requires three separate tool paths to be generated and joined together.
    A plain taper can be done with one setting.
    Pic 1 Shows hole to be machined.
    Pic 2 The countersink path with the tool drawn in the start and end positions.
    The coords from this drawing: start X7.2929 Z-1.4645 End X4.4645 Z-4.2929
    Pic 3 The transition path: start X4.4645 Z-4.2929 End X3.0818 Z-6.9279
    Pic 3 The taper path: start X3.0818 Z-6.9279 End X0.6700 Z-20.0994
    This link shows the type of paths that can be generated.
    http://www.cnczone.com/forums/showth...718#post188718
    Post #33
    Attached Thumbnails Attached Thumbnails Instruct1.JPG   Instruct2.JPG   Instruct3.JPG   Instruct4.JPG
    Jun 2006
    478
    Thanks for the info I'll surely be able to apply it somwhere :cheers:
