Hey all,
I'm having trouble with my TL-1. The spindle load seems unusually high. I've only had this problem the past month or two.
I'm cutting a 6" diameter, 6061 aluminum part, using 1100 RPM and .008" IPR and a .025" DOC. 1700 SFM. I'm getting around 40-50% spindle load and after a while of cutting at that load, things start to smoke from all kinds of places. I've tried all kinds of spindle speeds and feed rates. I can keep the spindle load low but the chips don't break and it hairballs up and I have to stop the machine every few minutes to clear it. The machine noticeably starts to struggle right when it starts to cut. Am I doing something wrong?
The insert I'm using is iscar CNMG432-PP IC8048. I tried another insert and got the same results. I can't find the exact one but this one is pretty much it
Thank you.
