586,129 active members*
2,899 visitors online*
    Aug 2010
    45
    fanuc i reset
    Is there a parameter to set the Fanuc I controller to reset to the beginning of the program from Auto mode. My Doosan will only reset to the beginning of the program from edit and I would like to change that to reset to the beginning every time reset is hit.
    Thanks for your help
    tony
    2932
    Re: fanuc i reset
    This has always been one of my biggest pet peeves with Doosan machines, but I have never found a Fanuc parameter that changes it. You might try posting this in the Daewoo/Doosan forum - there are a couple of real knowledgeable Doosan guys who answer questions there.
    Aug 2010
    45
    Re: fanuc i reset
    I have been doing this for 30 years and mostly just bumped machines occasionally but this caused the worst crash I have ever had. I know I won't do it again but someone else will.
    Feb 2009
    6028
    Re: fanuc i reset
    Every Fanuc I've ever been on regardless of brand ( been a lot) won't rewind the program in auto by pressing reset. I never looked for a parameter to change it.
    Jun 2007
    119
    Re: fanuc i reset
    I think it is possible using G08.6 (reset and rewind signal) and F0.0 (rewind signal) in PMC and parameter 3001#2 set to 1
    Jan 2009
    117
    Re: fanuc i reset
    After pressing RESET in AUTO mode:
    Select PROGRAM button
    Press OPRT softkey underneath the screen
    Press REWIND softkey
  1. Axis won,t reset on Fanuc O-MC
    By AZDEN in forum Fanuc
    Last Post: 07-05-2011, 09:16 AM
  2. Fanuc 10A- Reset apppear
    By nastek in forum Fanuc
    Last Post: 01-06-2011, 01:34 PM
  3. Fanuc OT, 520 alram will not reset!
    By Darens in forum Fanuc
    Last Post: 07-24-2009, 07:57 PM
  4. reset en auto d'un fanuc
    By skidoo in forum French
    Last Post: 03-09-2009, 01:15 PM
