586,488 active members*
2,565 visitors online*
    Aug 2014
    Using a 1250 machine torch on a PM45
    I was wondering if there was anyway to use the machine torch from a Hypertherm 1250 on my PM45. Thanks
    Jan 2008
    2247
    Re: Using a 1250 machine torch on a PM45
    The Powermax1250 torch uses different power supply end connections as well as torch end connections. You would need to do quite a bit of cutting and splicing of wiring and the air hose.....then you would have an older technology torch on the Powermax45....with lesser cut quality and shorter consumable parts life. I probably could be done, however it is not "plug and play by any means....and certainly not recommended by me!
    Jim Colt Hypertherm
    Aug 2014
    thanks for the reply.
  1. Hypertherm Powermax 1250 Machine torch questions.
    By pimpbike in forum Hypertherm Plasma
    Last Post: 01-04-2014, 12:43 AM
  2. 1250 torch cutting at an angle
    By Beefy in forum Hypertherm Plasma
    Last Post: 08-19-2012, 12:08 AM
  3. Powermax 1250 with automatic 100A torch
    By bdrotaru in forum Hypertherm Plasma
    Last Post: 09-05-2011, 01:04 PM
  4. T60 Torch on a Powermax 1250
    By Stout in forum Hypertherm Plasma
    Last Post: 08-04-2011, 10:26 PM
  5. Hypertherm 1250 with a T100M torch??? Short consumable life
    By Brink_ in forum Waterjet General Topics
    Last Post: 01-08-2009, 05:28 PM
