586,471 active members*
4,233 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mastercam 5 Axis Swarf
Results 1 to 6 of 6
    Oct 2008
    7
    I am trying to do a 5 axis program for a vacuum formed part. I'm running mastercam x4 and using a Thermwood c67dt to machine. A swarf really is the best toolpath option for the parts perimeter trim. One of my biggest problems i think is that i'm using a post processor updated from mastercam9. It works, kind of. When i post the swarf everythings runs as it should except for axis c. It rotates from 359.994 deg to 0.006 deg, which is the same position. but it causes the machine head to rotate back and forth constantly. The machine will move along the toolpath as expected but every 0.25" or so the c-axis will rotate 360 deg. If i had any tooling there it would crash into it. I'm trying to figure out if this is mastercam or my post processor or both. Is there a way to limit a specific axis in mastecam? I would be willing to trying tweaking the post processor but I would be a total nubie at it, though i would love to learn. Any help would be apreciated! And don't say, "Get a new post processor." because the boss isn't going for that.
    May 2012
    180
    Re: Mastercam 5 Axis Swarf
    Share you .mxc file and I'll see if I'll get the same figures.
    Oct 2008
    7
    I just added the file to my original post. Thanks for taking a look!
    Oct 2008
    7
    I've also attached the NC file I created.
    May 2012
    180
    Have you done 5 axis SIM before on this machine?
    Apr 2003
    3578
    So you still want to go with Swarf instead of Curve 5x with control lines? would you like to see a sample of doing this with triming a part on the model 67 machine in Machine sim?
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
  1. 4 axis swarf
    By joegalicic in forum Mastercam
    Last Post: 04-09-2014, 02:05 AM
  2. 5 axis indexing, not swarf, multi surface etc.
    By rroberto in forum Mastercam
    Last Post: 10-10-2009, 11:04 PM
  3. 5 axis indexing, not swarf, multi surface etc.
    By rroberto in forum Post Processors for MC
    Last Post: 09-08-2009, 01:57 PM
  4. Replies: 0
    Last Post: 08-05-2009, 08:11 PM
  5. Swarf Cutting 5 axis
    By Master_CNC in forum MetalWork Discussion
    Last Post: 11-13-2007, 06:20 PM
