586,475 active members*
3,412 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > CONVERT .DXF TO OLD STYLE .NCI CIRCA 1993
Results 1 to 5 of 5
    Jul 2015
    3
    I HAVE A HOTWIRE FOAM CUTTER DESIGNED AND BUILT BY AN OUTFIT THAT USED TO BE IN NEW JERSEY AREA.
    THE PC SCREEN READS "ACME FOAM" AND USES DOS FOR OPERATING THE 2 AXIS MACHINE.
    THE FILES IT USES TO CUT THE PATTERNS ARE .NCI FILE TYPE.
    I NEED HELP FINDING A FREE PROGRAM SOURCE (OR INEXPENSIVE IF POSSIBLE) FOR CREATING THESE .NCI FILES SO THE BUILT IN HARDWARE AND SOFTWARE CAN CUT CUSTOM STYRO FOAM PATTERNS.
    ANY IDEAS ANYONE? - - - THANK YOU IN ADVANCE FOR YOUR HELP!
    Apr 2004
    475
    Re: CONVERT .DXF TO OLD STYLE .NCI CIRCA 1993
    Is it a techno? I used to have an old techo control that took in *.nci files....basically old mastercam files without post processing i think. Mastercam 5.52 was what I was using at the time? Call a dealer about something that old and they'll just laugh....maybe someone has an old setup that can run a file for you to check?
    Apr 2004
    475
    Or, find a programmer that can make a program to read the dxf and make the nci. For foam cutter with examples to go from, might not be too hard. Technically the right post processor setup would probably work too.
    Jul 2015
    3
    Quote Originally Posted by gfacer View Post
    thats exactly what happens... dealers want me to ditch the old ($32000) and buy new again... frustrating
    Jul 2015
    3
    ive looked for .dxf to .nci converters but cant find any... a programmer might be the answer... thx
  1. Using a Dimensioning Style As a "Default Style"
    By nfrees114 in forum Solidworks
    Last Post: 09-21-2012, 02:37 AM
  2. Autocad Style Sketching vs Constraint Style
    By Beefy in forum Uncategorised CAD Discussion
    Last Post: 08-20-2012, 10:26 PM
  3. 1993 Vf-2p
    By fastolds in forum Haas Mills
    Last Post: 03-30-2005, 02:52 PM
