586,403 active members*
2,295 visitors online*
Results 1 to 5 of 5
    Aug 2014
    21
    Mach3 help please
    I'm not sure where to put this.
    I'm new to cnc and I finally got my machine to move under it's own power. I was trying some test cuts and it seems that the z axis is operating backwards. Is the z+ supposed to move downward?
    It looks to me like it's cutting the rapids instead of my pattern. Is there something that need to change?
    35538
    Re: Mach3 help please
    Go to Config>Homing/Limits and check "Reverse" for the Z axis.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Aug 2014
    21
    So z+ should move the axis upwards, correct?
    Thank you! I'll give that a try tomorrow.
    35538
    Yes, Z+ is up.
    Gerry
    Aug 2014
    1
    Mach3 help please
    H
  1. help me with 3d in mach3
    By uorya in forum Want To Buy...Need help!
    Last Post: 08-20-2012, 08:38 PM
  2. Why should i use EMC over Mach3
    By dresda in forum LinuxCNC (formerly EMC2)
    Last Post: 05-24-2012, 02:04 PM
  3. Differences Between Mach3 Mill and Mach3 Plasma?
    By cjjonesarmory in forum Mach Plasma / Laser
    Last Post: 11-18-2010, 04:12 PM
  4. Using Mach3 with Reprap extruderUsing Mach3 with Reprap extruder
    By router101 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-03-2010, 10:46 PM
  5. Mach3 help
    By woodguy60 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-01-2010, 10:55 PM
