586,281 active members*
4,297 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > wear offset control
Results 1 to 3 of 3
    Aug 2014
    1
    wear offset control
    hello,
    I have 6 Genos lathes on the floor. two of them are drilling 32mm holes on center by 9.5 inches deep.
    the operators have sometimes added a wear offset to the x axis causing bad things to happen.
    the control is OSP P200L.
    My question is:
    is there a way I can lockout the wear offset for a specific tool?
    like g10 on a fanuc for instance....
    A bit green with this control.
    I am thankful for any ideas,
    2tkgar
    Oct 2010
    134
    Re: wear offset control
    I don't think you can lock the wear offset, but you can limit it to I think 0.0005" or may be zero, or at the start of your program,
    you can write a line to put that X tool wear to zero or whatever you like, you have to look in the book to find the variable.
    My opinion.
    Jun 2008
    372
    Sure add the variable to the program with a negative value, the X axis variable for the wear offset is VTWOX
    in the program for tool number 8
    G00 X=VTWOX[8]*-1
    or even use the variable for the current tool
    G00 X=VTWOX[VETON]*-1
    If the value in the wear offset is 0 then this block will be 0
    If the value in the wear offset is -0.2 then the block will move the turret to 0.2
    If the value in the wear offset is 0.2 then the block will move the turret to -0.2
    or just set the value to zero
    VTWOX[VETON]=0
  1. Need Automatic Wear Offset
    By p8md in forum G-Code Programing
    Last Post: 10-22-2022, 03:43 AM
  2. mits 520am control geometry/wear offset even available?
    By rapid in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-03-2012, 10:52 PM
  3. wear offset not working!!
    By marcoagg3 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-07-2009, 11:35 PM
  4. Tolls offset wear.
    By jdgromi in forum Fanuc
    Last Post: 04-23-2009, 01:16 PM
  5. wear offset missing
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-20-2009, 05:35 PM
