586,378 active members*
2,575 visitors online*
Results 1 to 9 of 9
    Feb 2005
    122
    What shoud I choose lasercut or laserwork ?
    I'm about to buy a laser cutter/engraver. Supplier proposed me to choose from LaserCut or LaserWork.
    Those are 2 different motion controllers.
    Please advice since what should I choose since I didn't had any experience with those.
    Kind regards,
    DAniel
    Nov 2008
    382
    Re: What shoud I choose lasercut or laserwork ?
    Hi
    I would recommend to select a machine with a DSP AWC 608 and the software lasercad because this are the only affordable system who gets updatet all the time, the Lasercad program is totaly different then the lasercut and laserworks.
    greetings
    waltfl
    Nov 2010
    787
    LaserCut is more popular so it is easier to get help if needed.
    And do not mix Lasercad with LaserCut.
    CNC lasers, constructions, service
    Feb 2005
    122
    Thank you both for your opinion.
    Unfortunately I have to choose from LaserCut or LaserWork.
    I have read somewhere an opinion that LaserWork it's more updated or is updated more frequently .
    Also I have understood that LaserCut it's stacked on release 5.1 ? is it that bad ?
    DAniel
    Feb 2005
    122
    REading more about LaserCAd ( AWC608 Commercial DSP CO2 Laser Engraving/ Cutter Controller ) I have found out something that worries me :
    Is it true that LaserCut does not work on windows 7 ?
    DAniel
    Angela1 Guest
    Hi, i want to help you to solve this prolemble, lasercut & laserwork should based on the material you cut or work. You'd better see the quality of the samples of lasercut & laserwok first. Then make a decision. Besdes,i am a supplier of CNC machine. Kindly to help you anytime. MSN:[email protected]
    Best regards.
    Angela
    :cheers:
    Jun 2014
    611
    what materials would you like to work, base on the materials, then you can choose LaserCut or LaserWork.
    Nov 2010
    787
    LaserCut WORKS on Windows and the most know wersion is 5.3
    Feb 2005
    122
    I don't want to limit my activity only to cut something I may need to engrave as well.
    But my first application would be to cut wood with thickness of 4-6 mm.
    @cinematic2 - my question was if LaserCut it's working on Win 7.
    Daniel
  1. RDCam/Laserwork V8 - Want User Manual ?
    By TrickyCNC in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-17-2015, 09:05 AM
  2. who know the software of laserwork v5?
    By SPC-laser in forum Want To Buy...Need help!
    Last Post: 09-20-2012, 08:20 AM
  3. What kits shoud i used
    By ali12 in forum Stepper Motors / Drives
    Last Post: 02-20-2010, 02:14 PM
  4. What power supply i shoud choose??
    By sierra in forum CNC Machine Related Electronics
    Last Post: 09-20-2007, 02:06 AM
