586,440 active members*
4,069 visitors online*
IndustryArena Forum > MetalWorking Machines > Shopmaster/Shoptask > Increase Mill Spindle to Support Column Clearance
    Oct 2009
    84
    I just bought a Patriot VFD CNC and will be picking it up next week. Is it possible to increase the distance from the support column to mill spindle. I need to get a 20" part on the table with the ability to surface the entire part. I'd rather not do half the work and then spin it around to reach the other half. I can't tell from the pictures if the bridge where the spindle is attached is bolted to the support column or not. If it is, can I make a spacer block and lengthen all the wires?
    Mar 2014
    7
    Re: Increase Mill Spindle to Support Column Clearance
    If you're talking about increasing the distance between the mill spindle and the lathe spindle, I suppose you could - given enough time and materials. Have a look at another thread in this forum - "Making some nice things on my Patriot", to see what one owner did. Although he didn't increase the distance from the support column to the mill head, it looks like he could have. He did however eliminate the support column on the right side of the machine, allowing him to get longer pieces in the mill.
  1. Replies: 6
    Last Post: 08-16-2013, 09:53 PM
  2. Table clearance to column at max Y travel
    By dbrija in forum Tormach Personal CNC Mill
    Last Post: 12-10-2010, 03:38 AM
  3. For wood in a mill do I bolt a router to side or increase spindle rpm?
    By slashmaster in forum MetalWork Discussion
    Last Post: 05-12-2009, 06:41 PM
  4. dovetail mill column vs spindle servo
    By cncJerry in forum Benchtop Machines
    Last Post: 03-17-2007, 09:51 PM
  5. HARBOR FREIGHT small round column mill to a square column conversion.
    By motomitch1 in forum Vertical Mill, Lathe Project Log
    Last Post: 12-01-2005, 05:24 PM
