586,926 active members*
2,552 visitors online*
    Jan 2014
    27
    Laser cutter kit
    Hello,
    I am searching for a laser kit to adapt to my cnc machine, are these available and if so, can someone point me towards a good system that will work with mach3 if possible?
    I want it mainly to engrave wood, acrylic and cut balsa wood.
    Thank you
    Jun 2014
    611
    Re: Laser cutter kit
    do you want to replace the controller? can you tell me your CNC machine model?
    Jan 2014
    27
    No, not interessed in replacing the controller which is 5 channel btw.
    model of the machine is Heiz S 720T.
    They have a laser kit but it does not cut and I want one that cuts
  1. CNC Laser cutter versus CNC Plasma cutter?
    By squale in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-24-2020, 02:14 AM
  2. Laser Cutting Engraving Machine Laser Cutter 1400*900mm
    By cnc_laser in forum Commercial Laser
    Last Post: 07-10-2013, 08:52 AM
  3. CNC Plasma Cutter, Laser Cutter, Water Jet
    By antsals in forum Waterjet General Topics
    Last Post: 03-11-2011, 01:56 PM
  4. Why buy a Laser cutter when you can modify a laser engraver.
    By spacifique1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-13-2007, 08:39 PM
