587,058 active members*
3,926 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > How to remove error " Turret out of position" in Ge fanuc 21i-t controller for lathe?
    Jul 2014
    11
    Post How to remove error " Turret out of position" in Ge fanuc 21i-t controller for lathe?
    when i switched on the lathe machine which is using Ge fanuc 21i-t controller shows an error message as Turret out of position..
    Before that the shows 2 errors.
    1) Reference reqired
    2) 090 REFERENCE RETURN INCOMPLETE
    3) Turret out of position
    Can anyone tell me how to fix that error?
    Help me please because its so urgent.
    Re: How to remove error " Turret out of position" in Ge fanuc 21i-t controller for la
    I think there is an indexing problem or it is generated from yor turret encoder. I think this can help you.
    everything about cnc machine tools and components.
    Aug 2014
    7
    Move x and z axis in jog towardss spindle more than ur pitch of ballscrew says 10mm or 20 mm..make reference to both axis..after that index the turret..turret is not locked due to mechanical seatingproblem or clamp sensing problem..check mechanivcally seated and check clamp or inposition proxy or limitswitch
    - - - Updated - - -
    - - - Updated - - -
    - - - Updated - - -
    Jul 2014
    11
    Dear sudip,
    Thanking you for your reply. How can i check the turret encoder? Now i removed the encoder. when i give the command for tool rotation the turret keep on rotating and after sometime it stops by showing an error that "Turret out of position". Then again i rotate the encoder wheel by hand and check the command. Same problem occurs. If i keep the encoder on position and when i rotate it shows the same error and i can't able to make the turret in position. One more thing is that my index ring is on forward position. It is not coming back to the seating position which make the Position sensor Active. That is the main problem which i need the solution. Please reply me
    Jul 2014
    11
    If i check by changing the valve which is used for rotating the turret clockwise and anticlockwise i can able to take the index ring forward and backward. But it is not possible by using tool change commands. when i give the tool change commands the index ring come forward and the tool turret keep on rotating and stops by showing an error " Turret out of position" and i cant able to take the index ring backward for the seating position to make the position sensor active.
    Jul 2014
    11
    The Lathe machine which am using was ROMI BRIDGEPORT POWERPATH 15. please help me to figureout what the problem is
  1. Small lathe build with "ATC" Automatic Toll Changer Turret!
    By MarkGerard363 in forum Vertical Mill, Lathe Project Log
    Last Post: 06-05-2016, 03:55 AM
  2. Replies: 3
    Last Post: 06-16-2014, 09:36 PM
  3. Hitachi HT 20 CNC Lathe "turret index time over alarm" after battery change
    By surfit in forum Uncategorised MetalWorking Machines
    Last Post: 02-02-2011, 04:35 PM
  4. Interesting "Gross Position ERROR A" with no limit detection
    By A.A in forum Bridgeport / Hardinge Mills
    Last Post: 01-14-2009, 09:45 PM
  5. Fanuc 18t Turret alarm "1110"
    By senna95 in forum Fanuc
    Last Post: 10-18-2006, 05:03 PM
